Update: Okay I got the bleeder screw out, flush radiator and added new coolant. Some chunks of stuff came out. I was able to use the same bleeder screw. Didn't solve problem, but I'm sure it helped (or will help when I get the culprit fixed).
I just checked the fan, hooked it up to battery and it comes on so, just not the fan. I'm going to check the fuse again. Then I need to check the power going to the fan.
I did the test already to see if the coolant sensor was bad, turned car on and unplugged it, the fan didn't come on.
I already put a new fan relay in.
So I'm going to check power to the fan right now.
With the wipers, they were working, but I was changing the blades and guess I moved the drivers side around a little too much and the plastic linkage (?) Piece down inside broke?
