DOOR LOCKS
I had a similar issue with the power door locks about 20 years ago, I gave a ride to a fellow co-worker, everytime I hit the unlock button he pulled up on the outside door handle which prevented the door from unlocking, this happened about 5 times and then the power door locks stopped working, would not work from either switch or the auto door locks.
About 3 months later I was cruisin down the highway and the door locks cycled on/off and they have worked fine ever since.
I tell everyone that the constant pulling on the door handle while pushing the unlock button gave the BCM a headache.
There are two switches on the passenger door, window and door locks.
MIRROR
POWER SEATS
Your seat issue could be switch related or seat related.
The seat switch is a problem, only forward/back have worked on my switch for the last 10 years or so.
Unfortunately the seat switch has long been discontinued from Mopar and has never been available aftermarket.
Luckily I never have to move my seat, one day when I am feeling motivated I may take the switch apart and see if I can repair the contacts.
The Mopar # is 4373846 and is listed as "6 Way Power W/Recliner", the switch on the side of the seat for Lumbar and Wing is Mopar #4373856, the issue with lumbar/wing could be switch related or seat related.
WIPERS
As already stated the issue with your wipers is with the linkage bushings.
I did post parts info and a link on actually doing the repair.
CODE 41
If the Code 41 was set by worn brushes it will eventually return, each time the brushes stop making contact with the commutator the Code will set, even if it is just a momentary thing, eventually the brushes will wear down enough that they will stop making contact all together.
I also sent you step by step instructions on replacing the brush holder and where to get it.
COURTESY LAMPS
I just checked on my car.
The center dome light is supposed to be on with the door open, there is no way to manually turn it off.
FOG LAMPS
The fog lamp bulbs are replaceable, you have to remove the entire housing by disconnecting the lamp electrical connector from the harness and then removing the two screws on the bottom of the housing and the housing comes out from the front.
Once the housing is out remove the rubber boot, disengage the clip holding the bulb and remove the bulb.
The bulb # is H3.
If you bottomed out enough to hit the fog lamp be sure you did not damage the lower air deflector, the air deflector directs air up to the radiator while you are driving at highway speeds, you will overheat on the highway if that is missing or damaged.
OVERHEAD CONSOLE
My car does not have an overhead console with ambient temp info, it is BCM controlled, I can post diagnostics for you, just need to know exactly what is showing on the display and what is not.
HEADLAMPS
We discussed this earlier, chances are the issue is with the headlamp relay module, without a scanner to access the BCM diagnostics will be more difficult unless you can find a known good relay module and try it.
DISCONNECTED EMISSIONS/VACUUM HOSE
You will have to tell me exactly where the other end goes, you may have to remove the air cleaner box to do this.
COOLING FAN
The only way you will know if the fan is going to come on by itself is to allow the engine to run until it cycles on.
Backprobing the CTS connector and reading the voltage with a digital voltmeter will allow you to watch coolant temp to be sure it does not get too high, the fan will cycle on at 210 - 215 degrees F.
POWER STEERING
You may have to clean the engine compartment and underneath to determine where the fluid is leaking from, it could be the pump, the steering rack or one of the hoses.
Once it is all clean, start the engine and while someone looks under the hood turn the steering wheel stop to stop and keep doing that, turning to the stops increases pressure which may show the leak.
I replaced my pump and pressure hose in 2014.
