1 - 14 of 14 Posts
Category: Domestic
Status: Clean Title
I have a 1991 Dodge Spirit R/T for sale, in USA - Nebraska.
Mileage: 113000 miles
Engine Size: 2.2 DOHC
Asking price is $2350
For Sale: Red 1991 Dodge Spirit R/T one of 1208 total built in '91
car has: power windows/ locks/ driver seat, Abs (but is disconnected)
This car has been my daily driver for over 4 years, runs good, mostly stock, has just over 112,xxx miles.
Body: needs paint (clear coat coming off), does have some very slight hail dings, roof has some damage (a tree branch fell on it - from the last owner).
Spoiler has some of the typical "cracking", rust-through around the e-brake floor cable, some rust bottom of doors and trunk lip on the inside
2.2 DOHC T3 Engine: I have done: NEW: Cometic head gasket, ARP head studs, valve cover gaskets, front and side solid mounts, mopar oil pump, intermedite shaft bearings, 180 thermostat, timing and serp belts
also has: FWD valley cover, magnacore wires, champion plugs, 3" exhaust - no cat - just a summit "turbo" muffler, diode on map sensor trick (to prevent boost cut out)
I also replaced clutch cable, all brake pads, E-brake shoes, 1 or 2 rear E-brake cables, and pass side axle (just because the ABS "ring" was cracked - I still have not plugged the pump back in to see if it works now),
also has Eibach lowering springs and Monroe sense-a-trac shocks and struts, new front lower ball joints.
568 5-speed trans: could use a new clutch sometime, has new Booger bushings installed at all four points.
Newer windshield, wiper motor, new headlight bulbs, foglights rewired so can be turned on w/ just parklights
2-way Viper alarm w/ remote start , keyless entry and trunk pop.
Tried to describe as best as I can, I may have forgotten some things (I have done alot). This R/T has been a great daily driver w/ great gas milage. I have over $6K total into it.
Asking $2350 obo. I will e-mail back as soon as I can, I work alot
Thanks, Greg
Discussion Starter · #10 ·
more pics...
top of spoiler...
[/IMG]
top front of roof...
[/IMG]
floor around e-brake cable...
[/IMG]
Solid trunk floor w/ some dynamat I installed. The carpet liner and full size spare was removed just for the picture...
[/IMG]
Too far away. Great car though.
1 - 14 of 14 Posts
