1 - 20 of 28 Posts
<!-- BEGIN TEMPLATE: carform_post -->
Category: Domestic
Status: Clean Title
I have a 1991 Dodge Spriit RT for sale in Virginia
Mileage: 112000 miles
VIN: 3B3XA66A1MT601054
Engine Size: 2.2L
Asking price is $5000
Second owner purchased in Kernersville, NC
No rust. Body in great condition. New Paint, peeling long gone.
New headliner.
Performance Upgrades
Rebuilt head by Terry Walters in Roanoke
o Installed after market valve spring retainers for reduced wear on valve train components
o Port polished intake and cylinder head
o .074 Cometic MLS head gasket
o ARP head stud kit installed
o New lifters
All steel plugs replaced with aluminum plugs
Improved timing belt routing with adjustable cam sprockets for engine centerlining
Magnecor ignition wires
New FWD Performance short block without counterbalance shafts and camshafts
3 in. SS exhaust with high flow catalytic converter and Flowmaster 40 Series Delta Flow muffler
K&N cold air intake on turbo, not installed over very hot exhaust manifold
Oil cooler
SPEC high performance clutch
Eibach lowering springs with Koni sport strut inserts, KYB mono strut shocks in rear
This engine is ready for performance improvements, recalibrate computer for higher boost with new injectors, performance intercooler and upgraded blow-off valve
Original intake, exhaust and suspension components are available and included to restore to factory stock configurations if desired.
Complete 1991 Chrysler shop manuals included
Electronic timing belt tension device included and necessary for belt installation
Near I81 and I77 intersection in Virginia
More pictures as desired
<!-- END TEMPLATE: carform_post -->
Do you have the details of what was used in the shortblock? Stock rods or upgraded, main studs or no?
Discussion Starter · #7 ·
Sorry I missed your reply. No email was sent.
Do you mean the emergency brake area? The cables back by the rear wheels?
I can get you pictures. This car has never seen salt.
Discussion Starter · #9 ·
The short block was complete from FWD Performance.
Stores P/N: FWD 93-0785
Part Number: FWD 93-0785
Manufacturer: FWD Performance
Price $1600
The t-3 rebuilt shortblock is built to handle the horsepower of the might 16v lotus head motor can produce. Clean/check block. Brass freeze plugs, forged Venolia pistons, forged 2.2 crank, sealed power rings, clevite 77 rod and main bearings, and Mahle int. shaft bushings. Rods are shotpeened, tops drilled and ARP rod bolts are installed. ARP main studs added. Core consist of good t-3 block, forged crank and rods.
Purchased yr 2010
No counterbalance shafts on this motor.
Sorry, I thought no one had answered so I didn't check back. The parking brake cable where it enters the floor at the driver's side foot well. It is notorious for rotting at that location.
Also is this a new engine or original engine that was rebuilt?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Discussion Starter · #12 ·
I will try again to add more images but have not been able to yet...
Drag and Drop File Upload does not work
I don't like the way people post cars for asle and never mark them as sold, Is this car still for sale and is itn driveable. It would be my 3rd Soirit. First Turbo.
I have been complaining about that for years. I even gave some options to make the situation better but alas no one seemed to care. It makes it frustrating trying to use the for sale section doesn't it.
I hope you get a Turbo Spirit. They are still quick even by today's standards. Nothing quite like an unassuming 4 door sedan that shoots off the line.
Sent from my SM-N950U1 using Tapatalk
1 - 20 of 28 Posts
