1 - 9 of 9 Posts
hello,
the link to the neon board with cam info dosen't seem to clarify the differences between 2.4 and 2.0 cams.
although I'm pretty sure I have 2.0 cams as I got them out of a 98 neon sport, the pulleys are labeled 2.4 and they look identical. also, both the 2.4 and "2.0" cams have a "532" imprinted on them
the numbers i'm getting off my "2.0" cams are:
L-4
/288/
and
L-8
-254/
they both have a 532 cast in and have 2.4 timing belt pulleys. I didnt get more numbers off the 2.4 cams.
I'm hoping they are 2.0 cams not something that got swapped out.
ALSO, how is a good way to store these? i wiped oil all over the lobes, sprayed them with wd-40 and stuck them in a plastic trash bag and got most of the air out, but its not air tight. is this ok? im thinking i should pull them out and smear grease all over them, but would rather avoid that.
thanks for any clarification.
1 - 9 of 9 Posts
