1 - 2 of 2 Posts
I have a 87 daytona pacifica 2.2l t1 when running it seemes to make some noise ticking knocking ect.. the noise is not that bad but my question is do these engines make noise ?is it in there nature.I have noticed it more after I replaced the power steering pump that had a bad bearing that made alot of noise ,also this engine has 120k on it and has 15psi oil pressure at idle and I run 89 octain any help would be great hank you
Depends, wheres the noise coming from? Be more specific, you can tell if it's coming from the head region...which could just be noisy lifters. Each one of my cars clicked a little, especially on startup. If its while you're running and it sounds like engine, maybe you're running too low octance. I always ran 91-93 on all of my TDs.
1 - 2 of 2 Posts
