I am new to TD's but I have an 86' GTS I am doing the TII swap and adding some goodies and boost. For piece of mind I want to use stock TII rods and pistons with new rings. I have a line on a set in the classified section out of an 89' common block. Will these work in my older engine? If so I want them. Thanks for any input.
BTW... I am also looking for advice on a few other areas of this car. My planned setup was Stock TII rods/pistons, 1 piece intake, TII exhaust mani and Turbo, +20 injectors, 3" DP with a 3" cutout, TBI roller cam setup, underdrive pulley and 3bar MAP. All will be montiored with an AEM wideband. I was thinking of FWD stage 5 cal and run 12 pounds for cruising with the cutout closed and run maybe 16 or so with the cutout open for fun times. Is a stage 5 cal too much? I may get crazy one day and want to do more so that's why I was leaning towards the stage 5. It is unfortuneatly an auto I will run with a honkin' big cooler but, that will be the other weak link. I'm still collecting information/ research on what to do with that.
