Have an 87 shelby z daytona with a 2.2l turbo II from a newer daytona. Sat for 3 years, finally got it to my house and got it running. Like all old cars that sit for extended periods of time, there are issues that arise.
There's an aftermarket oil pressure gauge installed by previous owner that just dangles near the top of the dash. When i first start the car and the engine's cold, it will read near the middle of the gauge (45-50psi). Car isnt drivable yet, so i just start it and let it run to go through the bases.
Factory heat and oil gauge doesnt work, but after it runs for awhile the low oil light comes on and the aftermarket gauge will read almost dead 0 and will rise if i get on the throttle a bit. When this happens the engine sounds different, sort of like a rough idle but not as bad, but there isnt a knock or anything.
I'm thinking i should do a oil pump since i have a gallon of oil and a filter to put on, but im also thinking, maybe the filter is clogged and the oil just lost its viscosity from sitting.
On one hand, i do the oil change that might help it, but if i end up having to do a pump anyway, that would be somewhat pointless unless i can cleanly save the oil i drain.
From what i've read there should be 10psi of oil per 1000 rpm, and 6-9 was common at a hot idle. The pump doesnt look hard to do, unless its a timing belt pump (which i absolutely dread doing) so is there anything i should check before i jump on the oil train? ill try to record a video of it the next time it happens.
thanks for any input and advice.
EDIT: sorry for the mistake, just realized this was the wrong thread.
