I had a similar issue a while back and needed to keep the car operational.
As #2 intake rocker popped off I also removed # 2 exhaust and unplugged #2 injector.
The Engine ran fine with a miss although it was only running on 3 cylinders.
Not perfect but fully functional and reliable so I could evaluate the rest of the car.
I wasn't able to pull the head for a while but wanted it to be reliably functional.
My case was a dropped seat but the effect is similar to a sticking/stuck intake valve.
A sticking or stuck intake valve can cause obvious havoc with the other cylinders.
Keeping the exhaust closed insulates the havoc from the good 3 cylinders.
+ 20's with a T-II cal on a 2.5 is about perfect as this is what Cindy supplied.
520/ 555 have reverse in the correct spot, 523/ 568 are in the wrong spot, below 5rd.
I guess I'm lucky, my local Tims Muffler can do beautiful custom exhaust.
I agree with Todd though, most exhaust shops are useless!!
