I may need to find a 2.4L turbo head as the head I was sold as being a turbo model is not, it turned out to be from a 2001 NA 2.4L. My first hint was the exhaust manifold bolts, two of the bosses for them were not there on the head. If I want to use this one I would have to change all the valves to the turbo version due to the higher heat load. Cams are also suspect. It was advertised as an SRT4 head and manifolds. Exhaust is correct, intake is from a Cirrus NA 2.4L
Unfortunately the person I bought this head from had modified it to run on a 2.2L hybrid and it has a bunch of water return holes and oil supply changes.
