1 - 5 of 5 Posts
Hi,
I have ported my 2 piece intake for 52mm TB. Opinion are split on porting upper half of the runner to plenum.
Waht are you think ? ANy number and experience on that?
Thank you very much
Guillaume
guidsm said:
Hi,
Thank you very much
Guillaume
Use the search button for this section, was brought up in 2 massive threads, you might have to go back to December. Also check out www.thedodgegarage.com
I have read a lot of thread abour porting 2 piece intake...
Best thing to do it's to port the 52 mm opening and leave the rest like that..
Too bad..there a lot of meat to remove..
Thank you!
What I did was have the lower half matched to the head and the runners opened up as best as possible then opened up the holes that mate with the upper plenum to the gasket. I DID NOT touch the upper plenum holes but will only open up the TB mouth!
Now I hope works and does'nt cause the problem Gary was discussing on his site!
1 - 5 of 5 Posts
