After fighting w/ this full turbo/head install that I was hoping would be easy (HA, so optimistic), I finally have nearly everything together. S60/ported manifold/ported G-head/Remove Balance shafts/Custom windage tray/etc.
Anywho, Question 1:
Got a powdercoated valve cover from a user on here. It fits, but the PCV system is different. Its a single 90* bent pipe instead of what mine had a single small nipple, that went to a rubber piece that split into two, one PCV valve and one filter. Can this work on my current setup without heavy modifications? Also, I ripped that PCV boot trying to take it off... Anybody have a part number handy if I need it?
Question 2:
HOW THE HELL DO YOU PUT THIS 1 PIECE GASKET ON?!? I fought with it for a short time, but the frustrations of the oil pan gasket was enough for one night. Any tips/tricks to get it on (like, RTV it to the head or cover first?)
Anywho, Question 1:
Question 2:
