1 - 20 of 30 Posts
Hi , been awhile since I have been on. I had an old plymouth duster but it is long gone and a new project is in the works. I have a 2005 neon sxt atx I will be putting a turbo on it !
275010
275011
by
Had some nice weather today got the head installed and everything else. Need to replace the thermostat seal got damaged some how. Will replace it tomorrow . I will post more pics later.
You will need some form of rising rate fuel regulator or other means to allow system to add fuel under boost. Otherwise you will be pig rich driving in part throttle in order to be good air fuel WOT full boost.
So do you intend to use that flex hose for your piping, and if so, are you sure it will last under boost?
Discussion Starter · #11 ·
lmao
Discussion Starter · #16 ·
i checked my wiring everything looks good replaced my magnet with the one form my original cam (replaced it with in 04 junkyard cam i broke the pin the holds the cam in place) replaced the sensor and cleared the codes still popped the code. wondering if my timing is off a tooth ?
1 - 20 of 30 Posts
