Hiya. Colorado here.
Recently obtained a 3.0 auto Daytona to fix up for my gf to use. Installed some new shocks/struts, fixed a few electrical problems, and scheduled and a new windshield install only to fail emissions. It failed on high Hydrocarbons and because of a bad gas cap. It also has high NOx and CO. Results are at the bottom.
The car drives just fine. Seems to shift a little late, but shifts are as smooth as they should be. Could just be the way I drive it - its been a while since I've driven a v6 auto. It sounds like the car might have a minor exhaust leak.
Since the failed test I've done the following:
I'm planning on doing the following:
Unfortunately I do not have the correct tools to test the catalytic converter. I did shake the hell out of the exhaust and didn't hear any rattling noises coming from the cat. No smoke is coming out of the exhaust at idle or while driving. (edit: After replacing the plugs etc some smoke was coming out of the exhaust on first start. After driving for ~5 minutes it went away and no longer smokes at idle) The car has plenty of power and easily gets up to 70+++. I don't know how old the gas in the tank is, but I did add about 5 gallons yesterday.
I'm just looking for tips/advice. I've gotten some great answers on facebook, but they seem to be a bit sporadic. I'm hoping that I don't need a catalytic converter as Colorado adopted a new regulation earlier this year that requires California compliance for replacement converters.
- Cleaned EGR valve and verified function by applying vacuum
- Cleaned throttle body
- Replaced spark plugs and verified gap (Old plugs look very lean, see pic at bottom)
- Replaced spark plug wires
- Replace MAP Sensor (Spectra)
- Replace Distributor Cap
- Replace Ignition Coil
- Replace Gas Cap
- Replace O2 sensor (DENSO)
- Run fuel treatment (CRC Guaranteed to Pass)
