I never said I was going to swap it before I did any testing. I was just weighing out my options here and getting some opinions. Does anyone know if the input and output sensors from an a604 would be the same. I have known good sensors for one of those in a working car I could easily swap in and try. You can take your smart ass answer and keep it to yourself, I am not an idiot and would not do such a thing.
Yes you did, your first post was all about swaping transmissions in which I said you need to put a scanner on it. You may not be an idiot, however your posts demonstrate a mechanical ineptness. These are segments from some of your replies.
I have a 1996 Intrepid with a 3.3 and am wondering if the transmission from a 3.5 will have the same bolt pattern
I have a bad trans in my Intrepid with the 3.3, it is stuck in limp mode. (bought it this way)
but I would rather go with the very cheap transmission swap
I am thinking about trying to drop the pan and possible remove the valve body and get to the solenoid pack and swap it out.
the statements you're making demonstrat very little knowledge. your replies to me also showed that you were not comprehending what was being said. Without a scanner looking at trans data, you are not problem solving. your statement about swaping solenoid packs shows that you did not want to take my advise about putting on a scanner. Everything you've said in your posts is all about 'swaping this and swapping that'. you really don't seem to want to diagnose the problem, just want to keep throwing parts at it hoping to fix it. Wouldn't it be just a hoot to go thru all the changing parts, then replacing the transmission and having the same problem. hell it could be something as simple as a bad TCM relay, blown fuse, bad TCM.
Here's a partial list of things you could feel free to swap in hopes of solving the trans issue:
Entire transmission
output speed sensor (BTW 606 and 604 exact same part)
input speed sensor (BTW 606 and 604 exact same part)
PRNDL switch
Valve body
Solenoid pack
wire harness
TCM
TCM fuse
TCM relay
CCD bus line
and much much more.
