1989 Daytona Shelby 2.2 TII
'89 555
The rear main shaft bearing (bearing plate end) that has the snap ring. The FSM designates that for the 520 and 525 the bearing color is black and for the 555 the bearing color is blue. I have a black one for my 555. The old and new bearings look identical in size.
Main question is, Does it matter if you put the wrong color bearing in? Is the color the only difference between the blue and black bearings? What is the reason the FSM designates a different color bearings between the 520/525 and the 555? Thanks
I got an answer. Those bearing are the same no matter the color. The blue ones are no longer available and superceded to the black ones.
