Old School Hot Rodder
Does any know if it is possible to get a new 60 pin connector body for the SBEC connector? Does anyone have a good used one if no new ones can be had?
Thanks.
Thank you for the links, I actually found the 5013934AA at MoparPartsGiant.com for $14.81 + S&H, I ordered 2 as the S&H was the same at $15.10
Discussion Starter · #4 ·
I received my two 5013934AA 60 pin connectors today. FWIW, it appears to be the replacement for the EATX computer as only the outer 40 pins are open in the top. It came with 15 wires, 8 blanking pins, 5 large, 10 small splice crimps and 15 pieces of heat shrink.
Discussion Starter · #6 ·
The only problem I have is I will need to separate the two parts to open the center row of holes (21-40) without damaging the retainers in the main body (that's what is bad on the ones I have). I may try ordering a 5013935AA from eBay to see what holes it has.
