i need a underhood harness to convert my 91 r/t to 8 valve tii must be complete no cuts and 90 and up electronics for i am going to use vnt thank you nick
also when you say tape back one pin from tiii harness what do u mean i thank u very much for your help
What I mean is the coil on the TIII has three wires, the coil on the SOHC has two wires. The later epoxy coil that mounts off the thermostat housing uses the same pins as a TIII. Take the pins out of the TIII coil connector and put them in the SOHC coil connector. You will have one pin left over, tape it back.Yes its very easy to convert the TIII harness to 8 valve. All you really need is a 90-91 TI SBEC. I think he meant to tape off the injector control 2 wire going to the TIII coil plug(blue with yellow tracer) and splice the other two to a 91+ coil plug(colors match)
