85 Daytona TZ need help identifying a few parts
314 Views 3 Replies 3 Participants Last post by  ArmandHammer
2
This is the solenoid pack for the 1985 Daytona Turbo Z 5 speed car we are working on.
I have found out that the second one in from the radiator side is the waste gate control solenoid. Can anyone help me identify what the other 3 are for?
Motor vehicle Hood Automotive exterior Automotive tire Gas
Then there are these two relays on the drivers strut tower. The furthest left wire is a grey fuse able link that the wire is about 4 feet long and goes no where with a female bullet connector on the end. What are these two relays for? I am assuming one is for the fan controller? And where does that grey wire go? thank you in advance!
Syleng1
Motor vehicle Hood Vehicle Automotive exterior Gas
6
Quad Solenoids, Left to Right: Canister Purge, EGR, Wastegate, Baro Read
(The vacuum setup in the pic may not be entirely correct, use the page from the Chrysler Parts Catalog for vacuum routing)
Automotive tire Motor vehicle Asphalt Gas Road surface
Rectangle Slope Font Schematic Parallel
Product Schematic Font Parallel Rectangle
Relays
Motor vehicle Mode of transport Font Automotive exterior Parallel
There are only 4 wires at the Starter Relay on an 85, however, 84 shows the Gray wire and it runs to the Underhood Lamp, could have been a running change between model years.
Starter Relay Wiring
Red - Constant 12 Volts from Battery Through a Fusible Link
Yellow - Switched Ignition Power from the Ignition Switch, Power is only Present with the Key in the Start Position.
Brown - Output to the Starter Solenoid
Brown/Yellow - Ground, Through the Park/Neutral Switch on Auto Trans, Bolted to the Top of the Transaxle on Manual Trans
85-87 Starter Wiring
Rectangle Font Slope Line Schematic
84 Starter Wiring
Rectangle Font Parallel Slope Schematic
  • Like
Reactions: 1
Thank you so much NAJ! I greatly appreciate your help getting my sons car operational. It make sense now on the grey wire as it ram across the harness to the pass side since the hood has been off the car for 2 years now. I completely forgot about it.
  • Like
Reactions: 1
Thanks NAJ,
as I was putting my front hood back on this weekend I too was wondering where that grey wire went. That's because I took off the hood 3 months ago for an engine restoration. You knocked off (or answered) two birds with one stone.
  • Like
Reactions: 1
