In order to make my Omni idle & run I have to hold the ignition key ever so slightly before the point where the starter engages. If i let it rest in the "on" position after starting it the spark turns off (as seen with timing light on coil wire). Is there a wire in the engine compartment that I can just hotwire or put on a switch to give it power when I want to the car to run? I'm just trying to get it running so I can move it around under its own power.
TIA
-Brandon
TIA
-Brandon
