here's your choices for 1985
1 04323341 BRACKET, Mtg. w/o Air 60-78-90 Amp.
2 09437943 SCREW
3 06500273 2 WASHER, Flat
4 WASHER, (Not Serv.)
5 00152344 NUT, Lock
6 06101394 2 SCREW and WASHER
7 04241192 BRACKET, Alt. Adjusting
8 06032706 SCREW and WASHER
9 06500375 SCREW and WASHER
10 SCREW and WASHER, (Not Serv.)
11 04241283 STRAP, Adjusting
12 04241153 BRACKET, Adjusting
13 06500609 BOLT, Alt. Adjusting
14 04273289 SPACER, 90-100 Amp.
04273079 SPACER, 60-78 Amp.
15 ALTERNATOR
16 06501112 BOLT, Adj. Bracket
17 06500877 BOLT
06100878 WASHER
18 04323295 BRACKET, Alt. Adjusting
19 06500775 SCREW and WASHER
20 06100518 2 NUT, Flange Lock w/o Air
06100518 4 NUT, Flange Lock w/ Air
21 06100051 NUT and WASHER
22 04323383 ADAPTOR, Alt. & A.C. Comp. Mtg. w/100 Amp.
04323377 w/o 100 Amp
04241157 SPACER
23 SCREW and WASHER, (Not Serv.)
24 06101336 SCREW and WASHER
25 06101054 2 SCREW and WASHER
26 06101394 2 SCREW and WASHER
27 A/C COMPRESSOR, (See Group 24)
04209364 STRAP, Ground--6 1/2"
04268558 INSERT, Isolator
04268074 ISOLATOR, (Rubber)
04268068 SLEEVE, Alt. Rr.
04268067 SLEEVE, Alt.
05211210 STRAP, Radio Noise Supp. Ground
05213191 INSERT, Alt. Mtg.
