i have an 85 turbo z that i put a boost controller on when i put the boost up more than 7 psi the car cuts out at higher rmp like 4500-5000. any ideas on how to fix this problem?
Just curious as to of all the sub-forums, why you would post a turbo question in the tbi/carb(non-turbo) section?
Get an aftermarket boost gauge. Stock ones are notoriously innaccurate. IIRC, the 85 computer will hit overboost cutout at 11psi. Check for codes. If nothing there, and you aren't running over the 11psi limit, I would look for a fuel delivery problem.
