21 - 40 of 54 Posts
I can look for you on Monday.
What is the part # on yours or is it a Base or Premium (w/electronic cluster) BCM?
1990 Chrysler Le Baron 3.0 Cabriolet Specifications
VINnr: 1C3BJ4531LG473146
Body Controller, (Base) Stamped 4503112
however, i swapped from analog to digital a few years ago and to do that a premium BCM was required.
i can not find a number on my BCM, but i believe there was a number range 4020 in it orso.
is this helpfull?
yes, you find the rightone.
i received the flasher yesterday and try to install it today.
also i try to get an bcm trough this site.
well, the flasher won't work.
the turnlights are working but not the hazardlights.
the relay is also shorter then the accisting one.
i took the the relay from the donor cat, which is exactly the same blue one, but that does not work also.
now i start thinking about a loose wiring orso.
fuses are okay.
i keep looking and posting back to you.
There are two power feeds into the Dual Function (Hazard/Cancellation) Switch.
BK/PK wire from fuse #6
BK/WT wire from fuse #28.
The solid BK wire is ground.
Here is the Dual Function Switch test for the Hazards.
The pinout for the Hazard/Cancellation switch is at the top right.
Circuits L05 and L09 are Power in from Fuses 5 and 28.
Circuit Z01 is Ground.
okay, in that case, i have ground aswell as power on the switch on the cavitys.
i replaced the switch just to be sure with a spareone from the donor car, a working switch.
also tried 3 different relays.
fuse are okay
With the key on check for power on the PK/WT wire at the flasher with the T/S on and then with only the Hazard Flashers on.
The wiring is getting me confused, seems Chrysler took a long way around what should be a simple system.
With the key on and T/S and Hazards off what is the voltage at each terminal at the flasher? (Flasher must be plugged into the connector)
1)RD/LG
2)BK
3)PK/WT
4)DB/PK
Those numbers do not seem right, what are the voltages at the Cancellation/Hazard Switch connector with the key on/flashers off.
1)BK/WT
2)TN/LG
3)LG/WT
4)PK
5)BK
6)PK/DG
7)RD/LG
8)DB/PK
1)BK/WT: .794
2)TN/LG: 032 to 0138
3)LG/WT: .3
4)PK: NO PINK WIRE?
5)BK: 01.2
6)PK/DG: .291
7)RD/LG: 01.3
8)DB/PK: 01.3
Are you sure your meter is on the right scale (20 volt scale) and that you are connected to a good ground?
At the cancellation/hazard switch the BK/WT and BK/PK should both read 12 volts with the key on.
BK/WT: .80
BK/PK: 11.44
I assume that you meant PK/WT where you wrote 4)PK ?
The BK/WT wire is a 12 volt power feed from Fuse #28 and should read 12 volts with the key on.
Do you have 12 volts in and out of Fuse #28?
21 - 40 of 54 Posts
