1 - 11 of 11 Posts
Can anyone help me with this... i took the bulbs out and put new ones in and they still do not work.. the fuses are good and the dom light still works... any help with this would be great
Did you verify power in and out of fuse #6(20 amp).
Power from fuse # 6 runs to the illuminated entry relay located over the glove box.
The power feed in is an 18 PK wire.
Is power present at this wire?
I am assuming the problem has not been corrected?
Did you determine if this vehicle is equipped with illuminated entry?
You have to follow the circuit.
From fuse #6 it goes to a splice and to the illumination relay.
Checking power into the relay is the next step.
1 - 11 of 11 Posts
