1 - 8 of 8 Posts
That's great!! I've tried FWD and other sources will no success. Mine is fairly roached out and dont want to risk putting it on the road. Let me know how much your asking.
Thanks again,
Tim
Just some advice I can offer since I replaced mine just a few months ago. Be careful with the aftermarket ones that are cast. They usually have a pretty thick flange and will may cause you to strip the threads in the head if you use the stock bolts. They wont engage the same distance. See if you can find a nice original one.
If you can only find a cast replacement, be sure to clean the threads in the head very good and use longer fasteners. Good Luck.
Thanks for the insight. Dorman #902-3030 was the only cast aftermarket product I could find, or should say researched that was true to size. I had concerns being a cast product leaking but found that using a little care in gasket seating takes care of irregularities.
Discussion Starter #8
FWD Performance appears to still have the aluminum billet T stat housings
Under the engine/cooling page
I bought one years ago and it works great.
I spoke with her and was told nothing was in inventory at this time.
Detobias hooked me up.
1 - 8 of 8 Posts
