I have been having a power loss issue with my car. It started out on the freeway as a slight stutter while the throttle was constant, and now it is more erratic. If I start the car up now, it runs rough and the "power loss" light is on. When I push the throttle down halfway the rpms drop quickly and then with the throttle constant it revs up and down around the 1800-2800 range for a few seconds. After this happens and with the throttle still constant, the "power loss" light goes out and the rpms go up like they should. If I let off the throttle the cycle repeats itself. I have a 20sec video of this but can't figure out how to attach it to this post.
No luck pulling codes via the power loss light, and I don't have an obd1 available to pull codes that way either. I put a known good map sensor in place of the old one with no luck. The car is still running with the same issues. I also disconnected the battery and reconnected it to let the computer "learn" the new sensor. Don't know if that was needed but figured it couldn't hurt. I have a multimeter sitting in my toolbox but I'm not sure where to start.
I have gotten the suggestion to check my grounds, but is there any one particular I should be looking at, I mean there has to be a ton of grounds right? Bear with me folks, I'm learning as I go.
