Up forsale is my 1987 Dodge Daytona Shelby Z red with grey cloth interior. I am the second owner of this car and as it sits has 102,194 miles on the chassis.
New parts on this car are as listed.
Baker Engineering rebuilt 2.2 T-II engine
This engine was balanced and blue printed and features the folowing parts.
JE +.020 pistons
ARP main studs
ARP rod and head bolts
Comp Cams S-60 cam
Crane Cams valve springs
Mopar High RPM lash adjuster and slider rocker arms
Fel-pro gaskets
Mopar oil pump and timing belt
Total cost= $2705.37
External parts include.
Michigan Turbo stock rebuit Garrett T-II turbo
FM ported and Jet-Hot coated exhaust manifold
TU 3" swing valve Jet-Hot coated
TU 3" stainless down pipe
FWDP stainless braided oil and coolant lines
Magnecor Plug Wires
Mopar +20 injectors
Accufab afpr
Mopar stage 2 LM stock included as well
Engine pay parts include
MSD Blaster 2 coil
JAZ 1 pint catch can
Vibrant Performance custom intercooler pipes with ATP silicone connectors and t-bolt clamps
Michigan turbo FMIC
HKS SSQV blow off valve
Other new parts on the car are
FWDP 4-puck ceramic clutch
Walbro 255 fuel pump
Autometer Fuel,Oil, and Boost pressure gauges as well A/F ratio
Wheels are freshly powder coated original crabs with brand new Yokohoma AVS ES-100 225-50-15 tires
Drivetrain new parts
New axles
New universal joint in intermediate shaft
New ball joint
Energy Suspension contol arm and sway bar bushings
KYB gas adjust rear shock
New rear brakes including rotors,pads,calipers, and rear parking brake cables
I might have missed a few things parts are new with 0 miles engine has some break in time. Many original parts will be incuded if wanted sell car as is.
Asking $3500 any questions feel free to ask.
JE +.020 pistons
ARP main studs
Comp Cams S-60 cam
Fel-pro gaskets
Magnecor Plug Wires
Mopar +20 injectors
Accufab afpr
MSD Blaster 2 coil
Michigan turbo FMIC
New axles
New ball joint
