Hello, I have an engine from an 85 Daytona converted to T2 and an 87 A555 tranny with axles that fit. I was thinking of replacing my 85 Daytona with a 91 Daytona that has a non turbo engine. I would put my 85 engine and A555 in the 91. What issues will I have? Seems like the axles should work from the A555 and already have a clutch for the tranny. Motor mounts should work, right? I will have to add a clutch pedal. And the computer will be a challenge but I will probably do a megasquirt setup.
thanks for any advice you have.
Manual gearbox fit without a problem.
The problem may be with the pickup basket and the flywheel, but this is also solved.
Thanks for the reply. The pickup basket will be solved if I go to Megasquirt. What is the issue with the flywheel? Is it because of the starter?
