Sending unit or Fuel Injectors might be bad?
I can power the single fuel injector & it operates fine. do you know where the power comes from or what may be blocking it?Sending unit or Fuel Injectors might be bad?
naturally aspirated, NON turbo ... sry I thought I had this listed but it is only on my profile,Part # MOP-153RLBWas this the natural aspirated or aspirated engine?
to the best of my knowledge the injectors are 12v, most recommendations are to test with a 9 vt battery for no longer than 10 seconds. the injectors are to turn on for apx 1 second when the key is turned on ... this does not happen in my case. darkness is approaching so I must pack up for the day.Many times the oil pressure sending unit is a switch that lets the computor turn on the injectors.Check for proper connection of oil sending unit and power to it with the key on.
Do not use a test light because it can fry the injector because I believe they use only 3v and it will draw to many volts and fry the injector.
If not, then you can follow the wires back to where they get power from.
Hi again everyone, I would 1st like to say thanks to you for trying to help me thru this. 2nd I am hoping I can get some good straight answers on a couple of things. here goes ...thanks NAJ, I have tried to do the codes without the reader but I can not get the check engine light to flash them for me (off on off on off on in 5 sec?) as you can see above I have spark & the fuel pump does cycle when the key is turned on but no power to the injector. from what you have said, The injector wire runs from the ASD relay (possibly its is broke or damaged ?) I have removed the asd relay but did not know how to actually check it ..... the weather is cold & rainy here, hopefully I will be able to get back out there soon. I am hoping I can match colors on the wires & ohm them ... does 1 ground & the other to ASD? thx for your help![]()
well I tore into it again. I still have no power to my fuel injector. no power from the SMEC so I am guessing I must replace it.
Did you manually actuate the ASD Relay and check for power at the injector, + coil, fuel pump?well I tore into it again. I still have no power to my fuel injector. no power from the SMEC so I am guessing I must replace it.
