1 - 20 of 39 Posts
Gas prices seem to be rising and high octane fuel and turbos don't really mix with gas mileage. So a good MPG beater car was on the menu. Just picked up this Gem....
Definitely needs a head gasket and judging by the aluminum radiator and hardwired fan it's probably been running hot for a long time also the steering rack isn't even bolted to the frame and the brakes are pretty bad. I think with about $100 in parts it should be good to drive.
It made the ride back with insanely loose steering due to the rack bouncing up-and-down the temperature never went all the way up but it would just go up-and-down and the alternator belt kept slipping so the volts was going up-and-down..
Going to replace the bald tires tomorrow and pull the head will post all the progress on here..
1992 dodge shadow es turbo
Interesting project, these cars are long gone around my area. Love to see people keeping them alive. Not sure how much gas your going to save though, I swear my 92 turbo shadow gets better mileage than my old 94 2.2 tbi ever did.
My 89 Aries gets over 25 city 31 MPG same drivetrain but it's loaded with tools so I can't use it as a daily driver. My current daily is a 88 Town and Country Turbo gets 23-24 city and 27 mpg highway and Needs premium. Your Turbo 92 Shadow has a SBEC setup so a more efficient Sequential injection vs the pre-90 batch fired injector system and if your shadow is a 5 speed that's a big plus but if not even the 92 Turbo automatics have a lockup converter to save highway Mpg like the older TBI cars....
Very true my turbo is a 5 speed, and my old 2.2 tbi was the 3spd auto so not quite a fair comparison. I dd a Sierra 6.6 duramax loaded with tools, luckily I don’t have to pay for fuel as it’s a work truck, previous to that I had a fuel sipping 99 Corolla and then a 03 Corolla to which we upgrade to a Lexus rx300 which is currently showing average mpg of 19 not great, lol but the wife’s happy.
I wanted another one of these for the coming gas crunch.
Automotive parking light Land vehicle Automotive side marker light Car Vehicle
Car Vehicle Motor vehicle Steering part Speedometer
But all the 84-86 5 speed 4A-C cars are rotted away and gone (Only the 4AGE and RWD are still around). I used to get 35Mpg city and 45Mpg highway even with 377k on it. Seems the only 80's econobox to survive into the 2020's is the K car. All the Honda's were interference so those are long dead as are most of the other 80's cars. This was my yard a decade ago and even then I always kept a K car beater around...
Car Automotive parking light Wheel Tire Land vehicle
Discussion Starter · #6 ·
Update.
Finally went above freezing and took the head off. Took 2x the time due to rusted downpipe bolts so had to remove intake manifold and power steering pump to get a grinder in there took 4 hours total. No rusted bolts should take an hour. Also the egr pipe bolts snapped so considering using the 1994 Dodge Shadow TBI manifolds if they will work on the 88?
This is the worst I've seen I think.
Motor vehicle Automotive tire Wood Auto part Engineering
Head is cracked between valves too of course..
Wood Gas Circle Auto part Metal
Automotive tire Motor vehicle Rim Automotive wheel system Gas
Good thing I didn't do the clamshell method. Woulda been hydrolok time.
Water Circuit component Automotive tire Electronic component Auto part
Gas Eyewear Personal protective equipment Goggles Wood
Going to try to peen over the cracks and put some 80 grit sandpaper on some glass to resurface the head it's gotta be warped and I need a straight edge to check it with a feeler gauge. It looks like the compression and even oil was all mixing with the coolant.
For $30 I can get a set of rings and rod bearings re-hone it if it's worth it? Gotta drop the pan anyways get the goop out of it...
Looking good !!
I always run a large bastard file diagonally across the deck and head.
This gives me a good indication if there is warpage or not.
The idea is to have flat surfaces, more than smooth.
Shouldn't be any problem with the newer manifold.
I would never peen the cracks between the valves.
If it's a tall deck, now's the time to ditch the balance shafts!
Discussion Starter · #8 ·
Looking good !!
It's the 2.2 I'm looking at a Tall block right now it's been sitting in a guy's garage for 20 years. Machine shop wants 140 to do the head so I'm gonna figure out the way probably like this.
Discussion Starter · #9 · (Edited)
Updates
Head was cracked in the water jacket to the chambers. Good thing I didn't pay a machine shop. Ended up using a $5 thing (i dunno what it was for maybe counter top) from Home depot with sandpaper glued to it to clean the surface.
Purple Publication Rectangle Tints and shades Font
Font Art Gas Graphics Signage
Going to source a non cross drilled head. Found a $60 2.5 1986 Tall Block that has been in a garage for 20 years so the head from that should bring this car back in operation.
Today drained the oil water mix, swapped the rims, cleaned the deck some more and had fun with the loose steering rack.
The rack moved side to side up and down making the car a wild ride. This is with tires off the ground. on the ground the rack would lift up too.
So tried tightening the first bolt it snapped so had to saw a hole in the frame to replace it but the one above it wont tighten (this one let the rack slide but not lift like the other one) so will have to cut it off later. Also changed the rack bushing since the previous owner kept driving it loose (rack sliding) the bushing was paper thin...
Automotive tire Wood Automotive exterior Font Bumper
Water Wood Automotive tire Street light Road surface
New rims
Wheel Tire Window Car Vehicle
If anyone wants the steel wheels and the lug nuts (alloys need diff lugs) you can have em for free if you pick em up...
Next time going to drop the oil pan and pull pistons for a ring and hone job before the head goes back on. Can't see much crosshatch left and what is this?
Liquid Automotive tire Fluid Automotive wheel system Gas
Discussion Starter · #12 · (Edited)
There must be extra K cars up your way, they’re super rare in PA lol. Also I noticed that older prelude in that pic. I had an 86 (maybe 85?) with the side draft carbs. Was a cool car and styling was ahead of its time!
I've actually seen a bunch of K cars just sitting in people's yards and there's actually a few around here that are still driving around in really bad shape but still going.
The car on the right was a 89 Prelude SI
I had both Preludes 2nd gen and 3rd gen even the 4 wheel steering one. Pics from almost 20 years ago lol
Car Automotive parking light Land vehicle Tire Wheel
Never got those carbs to run right in the 84
Car Motor vehicle Hood Vehicle Automotive design
Did have cool styling though
Car Gear shift Vehicle Motor vehicle Steering wheel
The 89 SI ran much better (got it for $200 at the junkyard about to be crushed)
Got a solid decade out of it till rust took it over but it never skipped a beat and even made it from MA to Florida and back
Automotive parking light Tire Car Wheel Sky
How do you even fix this kind or rust?
Automotive tire Bedrock Wood Fender Formation
The car all the way on the left is actually a 84 Accord I picked up for $30. (lady wanted $300 but ps line blew then clutch and brake pedal both got stuck down husband begged me to buy it for anything) Everyone gives me that look when I buy these beaters
Vehicle Plant Grille Hood Automotive parking light
Wow those pics are a blast from the past. I remember when I got my prelude. Technically it was my first car (I had a ranger that predated it that I owned but I never fixed it or drove it lol). My brother in law was a mechanic and some one brought it to him with bad carbs. They decided they didn’t want to spend the money on new and gave it to him for like $100. It sat at his garage for a year or two and he gifted it to me. Red paint was faded bad so it got painted white quick (crappy job). I picked up used side draft carbs at the local junkyard (remember when useful things were still in the local yards?). I knew very little about mechanical work at the time as I was 15 and just getting into cars. Plus the spaghetti mess of vacuum hoses on that engine! Eventually got it running well but it was short lived as it was smoking like a New Jersey skyline. Very neat car though
Discussion Starter · #14 ·
My 84 Prelude was in a garage for a decade I got it for free they just needed it gone because landlord complaining plus scrap was so low u had to pay to have cars removed back in 2003. I spent 4 hours tinkering with it (good way to test the girl I was with she sat in my car the whole time no nagging) I finally got it running and we took it for a spin. Brakes were scratchy but there and the motor pulled ok but idle was off. I kept it around for a few years but never finished it so it was sold. I did take it on the highway and around town it just needed a good going through.
Once a car sits a full year like this just get rid of it because you know it will never get done. It just becomes one with the yard junk....
Plant Tire Car Wheel Vehicle
Car Automotive parking light Tire Wheel Land vehicle
Car Tire Automotive parking light Wheel Land vehicle
Discussion Starter · #15 ·
UPDATES
Took a ride and got the $60 2.5 TALL BLOCK.
Guy was real helpful we dissected the motor with almost no complications. One broken exhaust stud. Motor still spun and best of all no cracks in the head not even between the valves...
Automotive tire Wood Trunk Audio equipment Tree
Whole mess
Green Motor vehicle Vehicle Car Hood
I'm not using the cam but did notice wear on one of the lobes so it must have not been getting proper oil change intervals.
Wood Metal Musical instrument Fashion accessory Armour
The right way to put this all together is to change the stem seals lap the valves but then got to wait for parts.
Still have to
clean the deck
pull pistons clean and new rings
hone the cylinders
clean the head (80 grit or 120 grit on my tile thing)
swap the cam followers lifters
pull broken stud
then can finally reassemble this thing...
Discussion Starter · #16 · (Edited)
Update.
Got bottom end honed assembled. Seeing scratches on cylinder 1 and 4 from the new rings. Can't feel anything so hopefully it's fine. My $16 rings didn't show up in time so used OEM Mopar rings.
Aircraft Automotive tire Automotive engine gasket Vehicle Motor vehicle
Was able to pull the oil restrictor from a Turbo block I had lying around. Reason for installing it in this TBI motor is because without it the head can get overfilled with oil starving the bottom end at high Rpm. And a 3 speed auto on 2022 highways will be revving pretty high....
Lapped valves and installed new valve stem seals. Both of my valve spring tools barely fit so next time will need a better tool. Valves held water with no springs.
Light Circuit component Audio equipment Electrical wiring Gas
My ceramic tile resurfacing tool worked great on the head. Not even the .0015 feeler gauge fit under a straight edge anywhere on the head.
Liquid Purple Fluid Automotive tire Violet
Got tired of fighting the broken stud so used some ultra grey around that exhaust port.
Ended up using the 94 Shadow manifolds since the 88 manifolds were cracked rotted broken bolts and O2 stuck. Just gotta wire up the 4 wire sensor to the 3 wire plug on the car.
Had a slight complication with the passenger mount bracket hitting the corner of the head and headgasket. Maybe 1mm off. Ended up bolting it up anyways. Checked the old head and it has a tiny notch from the bracket. Never seen that one before..
Motor is fully assembled just have to reset timing belt and fill up fluids to test if it runs. If so will proceed to break in procedure.
Vehicle Car Hood Automotive tire Motor vehicle
Have under $50 in this engine "Rebuild" so hopefully it runs good..
Also had a chance to check out the underside and no rot holes. Just surface rust. Only a small section of rocker needs patched. Not bad for a 34 year old car that cost scrap price and still drove.
Wheel Tire Vehicle Automotive tire Motor vehicle
Going to scrub it then use oil based undercoating.
Man I am loving your TBI work. Once I get my convertible working again I wanna fix up my 1993 Voyager TBI and get some mo' performance going!
I love the fact that this TBI engine had blown a head gasket, ran for hours while I moved all my stuff with zero coolant and a flat tire and I STILL made it to my destination! The bearings rattle a little but it just keeps going! God I love these engines.
I heard if you shave the head to get like 11:1 an off-the-shelf Volvo timing belt can work.
Discussion Starter · #18 ·
I already added a 2nd Tbi gasket and the 94 exhaust manifold looks to flow better plus the intake has a divider thing inside unlike the 88 one so maybe it will make more power/mpg.
Carnivore Art Working animal Automotive tire Wood
First thing is get it started tomorrow...
I'm so totally f--ked in life right now but imma make it a mission to try and build my TBI van up and ride your TBI coat tails. Your budget updates are awesome. I feel like I will need to find out why my turbo 2.5 is running on 3 cylinders and apply some arieskcar budget to the problem
Your video where you drove your cheap purchase home hit me in places I totally adore, man, that feeling of buying a new abandoned car... man it feels amazing
I'm gonna record my 0-100 kph (0-60) see if you can compete with my clamshell performance 2.5 hahahaha
Hope you do a video the first time you go for a cruise!
Discussion Starter · #20 · (Edited)
Planned to go for a ride today but the exhaust didn't want to cooperate. Had to hold the exhaust up and the donut gasket along with the bolt/spring then nut. Practically impossible and I forgot there was a broken bolt stuck at the exhaust....
Did get enough hooked up to fire it up though.
Still need to
fill/bleed coolant
get 2nd exhaust flange bolt in
Wire up the 4 wire O2 for a 3 wire plug
Sealant on cam caps (Forgot)
Race it to seat rings...
1 - 20 of 39 Posts
