I currently have the engine out of my 89 CSX and while it is out I plan to change out the front and rear main seals along with the oil pan (cam seal already replaced).
I verified it is a 5 bolts sprocket and wanted to know if this kit will work for pulling the crank sprocket off or do I need to get the 6793A puller?
www.harborfreight.com
Also, any tips to this task with the engine on a stand? I already swapped out the rear main seal in its housing, but need to get the old sealant off the housing so I can apply some anaerobic sealant to the housing and install if back onto the block.
Thanks in advance.
Bolt-Type Wheel Puller Set
Amazing deals on this Bolt-Type Wheel Puller Set at Harbor Freight. Quality tools & low prices.
Thanks in advance.
