complete engine includes head, block, crank, alt, water pump, flywheel, clutch, valve cover, throttle body, exhaust manifold, sensors, belts, distributor, spark plugs. Not sure how to accurately identify a common block but this engine came out of a 1989 sundance/shadow. car had 88K actual miles, it's just sitting in my shop. has round tooth timing belt.
I have two 2.5 turbo short blocks. Both are cross drilled and are turbo ones with the oil drain back hole in the block.
One is in SE PA and the other is in NC. I may be able to deliver something between Charlotte and CT.
Where are you located??? Makes a difference.
PM if you are interested. I will sell either as a bare block or a complete shortblock or as a complete engine.
