1 - 10 of 10 Posts
Hi guys, I'm back, been a while. Anyway the turbo mechanic I had, supposedly moved out of the country. So my van has basically been sitting in garage. But I need to drive it now and the water pump is being changed. New mechanic, he said it was a real tough job. Just curious do you have to remove the timing belt to do this? I didn't think it would be that difficult a job. Just need opinions on replacing water pump, is it a complicated job?
No, you do not need to remove the timing belt to replace the water pump.
The water pump is mounted to a separate housing which is removed to change the pump out of the vehicle.
There are 3 bolts holding the water pump housing to the engine block.
It is probably a +/- one hour job if all you are doing is replacing the pump.
1)Drain Cooling System (See Drain/Refill Cooling System)
2)Remove Belt
3)Remove Stationary Bracket (See Stationary Bracket)
4)Remove Lower Radiator Hose and Heater Hose From Water Pump Housing
5)Remove 3 Bolts From The Housing And Remove The Housing From The Engine Block
6)Remove Pulley From Water Pump
7)Remove Water Pump From The Housing.
8)Reverse Procedure To Install
Remove/Install 2.2L/2.5L Water Pump
Proper Drain/Refill Of The Cooling System
Proper Remove/Install Of The Stationary Bracket
... New mechanic, he said it was a real tough job. Just curious do you have to remove the timing belt to do this?...
This new mechanic is priming the pump for a big invoice. Everybody has to eat, but find a different mechanic that has an ounce of honesty. Like NAJ states, timing belt removal doesn't come into play at all. 1-2 hours tops for labor, start to finish. This mechanic calls this a tough job, RUN away fast, they're no mechanic.
Legendary Driver
The worst part about changing the water pump is getting coolant everywhere. The best part? Using a pre-89 pump, porting it and shaving every other fin off then putting it on your motor with the right belt to run it the correct way.
Well it's hard to find a reasonable good turbo mechanic. I got this guy from a friend and he's a retired CTA mechanic, so I figured he knew his stuff. He didn't charge me anymore than originally quoted. But... when I picked up the car, everything was alright for about 45 mins. then the alternator belt broke, car started overheating. I let it cool and added more antifreeze, which believe it or not, I was so pissed I didn't pay attention and started to put oil in radiator, (same color gallon jug). OH NO... caught it right away maybe got 1/2 cup in there. Took car about 1/2 mile back to mechanic and told him to fix it right.. My radiator and fan have maybe 50 miles on them. The belt wasn't that old, but maybe from sitting it got a little dry rotted? Obviously something wasn't right, maybe belt wasn't tightened properly or maybe overtightened. Dunno!
Does anybody know a good turbo dodge guy in Chicago that I could use as a mechanic?
OK, I used van all weekend. It started to overheat on both Sat and Sun. Replaced radiator cap Saturday and then Sunday hose started spraying all over. It had a leak by clamp. So, I replaced it. I think everythings ok now. BUT, another problem appeared Sunday. As I hit a roadway with higher speeds, van wouldn't accelerate properly. Tried giving it more gas again and heard and felt a jerk, almost like a trans slip. But not the trans. It's shifting ok. Now I had acceleration before this. So what happened all of a sudden? When you take off it can accelerate to 20-25mph. Then you have to gradually wait for it to gain speed.
It was installed as I said previously. I think everything's ok now. I changed rad cap and hose that sprung a leak. So far, so good, but I haven't gone to far. This weekend will be the test. Wish me luck, lol. Plus I have turbo guy coming out Sat. So we'll be double checking everything. Thanks for asking 😊
Discussion Starter #10
The idiot that did my water pump had my timing all out of whack. Hoses leaking. So we got the timing set through distributor. But will get back to belt itself later. Been really busy trying to keep other car up. R&P, along with power steering pump replaced. Can't get check engine light to stay off. Changed all O2 sensors, plugs, But that's a Ford for ya. Anyway, Dodge vans running much better now. And needless to say, that guy is never touching my cars again. Thanks for all the help guys. And Merry Christmas to you all. Have a nice holiday!
1 - 10 of 10 Posts
