61 - 70 of 70 Posts
Sounds like your onto something. That is exactly what it sounded like in your video. I'm sure you don't feel lucky at this point, however pulling the fuel rail and injectors is super easy on this manifold vs. the 2 piece designed intake. If it were me, I would pull the injectors and fuel rail as an assembly and reconnect the inlet and outlet of fuel line back together to vehicle, unplugging the rectangular injector connector. Jump the positive side of coil (like before) to get the fuel pump to pressurize, and run some jumper wires to negative and positive side of injector harness. FYI- The green with black tracer is the same 12 volt positive that connects to the positive side of coil.
FYI- The SMEC provides 12 volts to all four injectors all the time key is in run position and by manipulating the ground for the injectors they batch fire two cylinders at a time. 1&2 batch fire, and 3&4 batch fire. So, you can then run a jumper wire to the negative side of the harness connector and ground. The 1&2 negative side should be a white with dark blue tracer colored wire, while the 3&4 should be a tan colored wire. You can run them into clear container(s) to observe spray pattern (or not). I'm guessing three will not (lol)! Disposable plastic water bottle(s) works great. Breaking the electrical connection repeatedly may get them to work.
After you've concluded they don't externally leak, you can decide to have them rebuilt or not. If they do leak externally, they cannot be rebuilt. MrInjector.com (Bill Johnson) does an outstanding job rebuilding them. Last I knew he charged around $17.50 per injector. Complete with before and after flow sheet. Turns them around in 24 hours or so. You should inspect the rubber boot around each injector, If they are cracked, it may be the reason the injectors are not firing, due to corrosion. To get the EV1 electrical connector disconnected, you need to use a very small screwdriver or pick, and remove the stainless wire attachment. After removing, the injector connector will come right off. To install, you can assemble stainless wire on connector, and just snap into place. Also make sure all connections are good and corrosion free at the injector harness connector.
Good luck!
If you are suspecting the injectors are not being pulsed or are being pulsed but not firing...
1)Noid Lights will tell you if the injectors are being pulsed.
You can rent them for free at AZ.
You can also use a Logic Probe, 12 Volt Test Light, Lab Scope, IMO Noid Lights are the easiest and most efficient method.
Once you determine that all 4 injectors are being pulsed you can test the injectors themselves.
2)To test the injectors themselves without an injector tester or scanner...
a)Check resistance across the injector terminals.
Resistance should be 2.4 ohms.
b)You can manually pulse each injector to see if it is operating.
Connect your fuel pressure gauge
Connect jumper wires to the two fuel injector terminals of the injector being tested.
Connect the jumper on the + injector terminal (power feed) to the battery + terminal.
Connect the other jumper to the injector - (control side) terminal.
Turn the key to the "On" position which should actuate the ASD Relay for one second to
pressurize the fuel rail.
Momentarily touch the jumper connected to the injector - terminal to ground.
(The longer you touch the jumper to ground the longer the injector will stay open, if the fuel rail/injectors are still in the manifold that fuel is going into the engine so do not hold the injector open for long.)
If the injector pulsed fuel pressure should drop.
You can also do this from the injector harness connector which may be easier than trying to place two jumpers in the injector without having them touch each other.
The 2.2L/2.5L engines fire the injectors in pairs, 1/2 and 3/4.
If you choose to do this you will need to disconnect #1 injector when testing #2, and disconnect #4 when testing #3 and disconnect #3 when testing #4 so you are only pulsing one injector at a time.
3)The wires at the injectors are as follows.
a)DG/BK is the power feed from the ASD Relay.
b)WT/DB are the ground side control for cylinders 1 and 2 from SMEC Cavity #9 of the 14 pin connector.
c)Tan(TN) are the ground side control for cylinders 3 and 4 from SMEC Cavity #10 of the 14 pin connector.
PM being sent with additional wiring.
Personally, I had a case where all the injectors wedged at the same time. What I did not do was become ridiculous myself.
Dismantled the nozzles on the stand cleaned installed in its place. And lo and behold, the engine worked perfectly.
Discussion Starter #65
Finally forward Progress!!! Took the whole rail off and tested it as mentioned above. I could only get injector one to pulse. Took all injectors off and bench tested them. None of them other than cylinder 1 will even click. I just ordered 4 Bosch remans, hopefully that does it.....
Discussion Starter #68
well everyone we've made progress, not perfect but progress. Got the injectors in today, I opted for Bosch re manufactured instead of Chinese ones. Put them in and they all tested to pulse good. Went to start....no dice, it tries a hell of a lot harder but it won't stay running. After playing around for an hr or so I am able to get it to start and run if I pump the gas then hold down the pedal indefinitely. She won't run clean, just a mess of back fires and smoke nonstop, but running non the less. Once I take any pressure off the pedal she's dead. What now??? At least I'm finally making forward progress
Glad your making progress. I see a flicker of light at the end of the tunnel (lol).Hang in there!
Any codes or dash power loss light yet? Your MAP sensor reading seemed quite a bit off last time you posted. In post #58 you were talking about the MAP sensor, but posted picture of TPS sensor? Assuming this is just a slip. MAP is on passenger side strut tower and TPS is on throttle body (on drivers side).
To check your TPS sensor with KOEO, signal wire should be around 1 volt at closed throttle, and as you open throttle, it should progressively and smoothly increase to around 4 volts at WOT.
MAP sensor without vacuum/pressure applied to it should be around 2.30 volts. This will vary at bit as well. If you have the tools to apply precise pressure to the MAP sensor, it should increase in voltage as pressure is applied to it. Somewhere around 14-15 PSI, it will max out between 4.3-4.9 volts. This will vary between MAP sensors year to year and sensor to sensor.
Bad vacuum leak will also do this as it produces a high Map signal and the ECU throws lots of fuel at the problem. Ask me how I know this??? Yup, my foot "slipped" on the right pedal, the boost went up and ripped apart one of the vacuum fittings. I used over a 1/4 tank of gas to go 25miles. Easy fix once home.
61 - 70 of 70 Posts
