Please be patient cause I'm just getting crazy by just reading searching for hours and days still i'm not understanding. What I need is someone to guide me on what I need first for my 89 smec socket to have atleast 2-4 cals.
First thing I need:
1) Smec socket
2)EMUC2818 Emulation Cable 28-pin 18-inch
3)Moates 2Timer
4)Switch, What type ?
Is there more please fill me in. I have a 27sf512 chip in the socket. I will need someone to burn the chips once it is done. I don't wanna learn how to burn chips I'll go nutz:bang head unless I have someone here to show me.
Wife is going nutz cause i'm on the computer for hours and days trying to learn to make things easier for my van. I got my mtx-l wideband today yeah.
I THINK you could have two seperate calibrations if you had a chip burner. Or something that plugged into your SMEC wiring that could burn it for you.
Basically all you would be doing is have the chip burner program on your computer. Someone wpuld write the cals for you, and you would burn them onto the chip yourself.
Someone who burns cals would be a ble to elaborate, but unless you have a standalone system, I dont think you can have two calibrations on the same chip, you'd have to re-burn them each time.
Is this mean I can talk to someone by email of what I'm running on my 2.5 to do the cals for me and send it to me by email and I do the burning myself.
Love to find someone who knows how. That would be blessing and much easier for me. Any volunteers I know we have some here.
Read my post couple of time and post #2 caught my attention.
You don't really need the extender if you're going to run a cal switcher. The extender makes it easy to swap chips by putting the socket somewhere easy to get at (rather than closed up in the SMEC).
The Ostrich is nice for tuning, but some have had issues using it daily.
Finally, MP Tune comes bundled with a great little program called the BIN Stacker that will put together binary files into 1 file for the cal switcher (should work for either the 2Timer or the DoublePlay).
Is that all I need. Just that 3 items. Can you make a package of what I need more to run with this 3 items that will work with my smec socket. I like that switch makes me think i'm going in the right direction of what I wanna do.
you need the 1990 SBEC harness and computer to add the 32pin socket. But if you can solder well enough for doing a whole socket you should be able to build the flashable SMEC too
Yeah I've seen and read that 32 pin instruction and I don't think I wanna go there.
I like to concentrate on this route on post#6 if its a plug and play. I like to atleast have something like street and race mode on a switch.
Shelgame can you make a list of what I need to go this route on post #6. So I can picture and study on how I will puzzle this things together to run it.
You know something that I don't have to keep opening the hood to keep changing something.
flashing doesn't take long and you can have as many cals as you can fit on the HD. Without taking the computer out or popping the hood. If you can flash it you can make changes when you add flow parts like a bigger IC or exhaust or turbo. If you get mods and the cal doesn't match you'll need to get the chips in the mail
You will need a burner, and go download MP Tune. The Binstacker program is built in and it was designed specifically to put 2 cals together for the DoublePlay.
I would say the Moates Burn2 is good, especially if you're new to cals. It only does a couple of chips, so there's really no fiddling to get it setup. Plus, MP Tune can also write cals directly to it - a nice plus. You can also get a 'Willem' style programmer for a little bit less $$. But, they do a ton of chips, so getting one setup for the 27SF512 can be a PITA at times. Plus, the software is kind of old, and getting ti setup in Win7 definitely is a PITA. Unless you like fiddling, go with the Burn2.
