I removed the balance shafts and plugged the oil supply to them in the 2.5 (injected, NA) that I put in my '86 GLH look-alike. It has much more power than the stock TBI 2.2 in my '88 Omni, but there is very noticeable vibration at idle, especially when the A/C is on. I'm not sure if the performance difference off the line is due to the bigger engine or the deleted balance shafts, or a combination of both, but I DO like the increase in power. If I give it an additional 1 or 2 hundred RPM at idle, the vibration goes away. WHen the engine is cold and still idling slightly higher, there is no vibration, or very little.
