1 - 8 of 8 Posts
Buy a 1991 turbo Daytona and swap everything over.
With some work, sure. Just get the wiring diagrams for both and start matching up wires.
Swap in a turbo drivetrain as it would be difficult and somewhat expensive to convert a TBI motor to turbo properly.
BTW, the turbo oil line runs from the front of the motor where the oil pressure switch and oil pressure sender are installed. The oil return runs into the back of the block (there's a boss there that needs to be drilled out to 2/64 and have the proper fitting inserted and peened in place) The coolant line run from the back of the block opposite of the water pump inlet to the turbo. Tht's one more fitting (1/4" pipe) to be drilled and tapped. The coolant return line runs to the side of the head above the coolant temperature sensor. The cam, valves, springs and shrouding of the valves are different in a turbo car. The pistons are of course different as well. The torque converter or clutch is different as are the final drive ratios and strength of the gears. The turbo automatics had stronger clutches and other internals. There may be others, but that's all I can think of right now.
Good luck,
Stefan
Discussion Starter · #7 ·
Stefan
so i should probly put in a trans out of a turbo car then?
1 - 8 of 8 Posts
