1 - 6 of 6 Posts
Ok got a question, I know anything is possible but is there a way to use a 91 interior mainly the speedo,tac,gas,oil,batt,headlights,wipers in a 85 ? I have a 91 dash i like the style of it more than the 85.Im not sure if there is a way to use the old gauges in the newer dash.I know they changed stuff inbetween them years.I just figured i would throw it out there and see if anyone had any idea`s .I have found a artical on someone doing it .
http://www.turbo-mopar.com/forums/showthread.php?32240-Daytona-Thread-Post-Pics&p=414139#post414139
Daytona Thread-Post Pics - Page 5
Yes it can be done, the fastening points are unchanged, but you will need a complete donor (90-up) car for sure. Regarding electrical, the best bet is upgrading to the SBEC wiring harness, this includes the dash harness and engine harness. SBEC is a better system than the old Logic Module/Power Module system to boot.
The reason being, is that the 90-up clusters communicate with a BCM and use a data-bus interface, where pre-90 used simple voltage on wire. It may be possible to only swap the dash harness and BCM, and custom wire to the BCM but I have not investigated it.
Either way it's a decent bit of work and not a direct plug and play swap by any means, but it is possible!
I do have a 91 harness but the mice ate alot of it and it`s from a Na automatic car and mine is a turbo 5 speed.
to try to do this is ... not the easiest plan
to try to do this with bits and pieces from here or there and do it to an 85 IS a really BAD idea..
IF you found a rusty/wrecked parts car .. complete and running then it wouldn't be as much of a challenge
but start with something as a whole and TRANSFER it COMPLETELY as a whole
then you have reasonable expectation of success
and .. don't forget
the outer door window trim & mirrors... you're gonna need 'em too
the 90 ^ door panels come up higher at the bottom of the windows - thus the glass "looks" shorter
1 - 6 of 6 Posts
