Anybody know the trick to fix the fender problems whit this cars or I got to take it to a body shop to fix it .I can't open the passanger door whit out dent it
loosen all the fender bolts and pull the fender forward till it clears.sometime you can just loosen the bolts on the bottom of the fender and pull it out abit and the door will then open inside the back of fender line.Also you can pull the fender out away from where the door hits it,but best option is #1
It did not work for me and i caused damage to the door and fender. its bent now beacuse i have to open the door it looks bad will have to go to a bodyshop now I see others daytonas with the same problem .
