daytona, lebaron thats about it, but you have to make sure whether abs or non abs as the axles are different. i got an abs one for my rt from autozone, it was in stock
the only way ABS or no ABS would matter is if you have ABS and pop in a non ABS axle without swapping over the tone wheel. They pop right off if tapped easy and straight.(just don't beat up the teeth) If should go right on a non ABS axle. Or if you get an ABS axle and you don't have ABS you can put the axle in with the tone wheel still on it. 15 years ago you had to swap this off the old axle onto the reman.
Tim
