2.2 N/A
Ok, the best way I can describe this is that the 1-2 shift occurs correctly but the 2-3 shift doesn't happen unless you shift to Neutral then back to Drive. Then it downshifts back to 2nd. Here's where it gets weird...when I manually shift to 1 the gas pedal gets very tight, when you shift to 2 it gets less tight and even less when in Drive.
Its a very strange phenomenon.
Is this some weird TV cable spring issue?
