Hiya,
I recently acquired a 93 daytona with a few minor issues. I believe someone plugged the battery in backwards at some point as both 60a alternator fuses were blown as well as some interior fuses etc.
Currently all fuses on the car are good and pass continuity checks. Everything works EXCEPT for the foglights and the turn signals.
The turn signal switch did have broken solder joints where it connects to the sub board. I reflowed all connections between both boards and still have no turn signals. I also swapped the turn signal switch with anther one of unknown function. The "replacement" feels much more solid and less worn.
Shaking/hitting things makes no difference. The bright function always works as do all of the other switches.
Do some of these connections run through the instrument cluster? I can pull that out and reflow all of the connections if need be.
