i have a 98 caravan. now first started driving it today it was fine. then about 10 miles or so it would not upshift from the stop sign. just stayed in first. so i tried shifting it manually. it started in first then when i put it in 2 it shifted, then in drive nothing. so i tried in drive again and it just stayed in first. any ideas? levels seem fine and everything. please give me any ideas. i use this dailey for work. thanks again.
if its an OD trans your in limp mode. It only has 2nd and reverse. You have a code in the trans computer. restarting the engine will reset it untill the code resets. You need a scanner to pull that code.
Tim
I don't know what type of scanner autozone uses so I can't answer that but to pull the code you are looking for it is not in the engine computer the trans has its own computer. My snap on scanner would pull the code.
Tim
