Do i have to change out my hubs because the c.v. axle seem like the splines are to large to fit into the spindle:bang head.
If so how so i do it by getting a whole new spindle or can i have new ones pressed into the old spindle?:confused:
Please help im so close to having my car back on the road.:thumb:
Are they a tapered fit because i have put many c.v. axles in already even though i am only 19 and these ones seriously just seem a little to big
I looked up autozone.com just to check the part numbers of the hubs. It showed the same part for the hub assy as an 88 Daytona, which should be approximately what a 555 came out of. Check for rust on the splines, both on the axle and in the hub. wire brush it clean and put grease on it. Try to insert it without the other end in the trans to verify the angle isn't causing the problem. Good Luck!
