Hi there:
I understand that you are not aware of where the replacement transmission came from. In the case of the 604, the replacement trans needs to come a similar vehicle as the one in yours. Different year models & vehicle applications will have different possible gear ratios & different coded EATX (trans controller), this is NOT the engine controller located on the drivers side of the engine bay. This the controller on the passenger side just behind the headlight assembly. The EATX has to be *flashed* to match the trans.
You're getting codes 50 52 54 which the EATX is telling you that the gear ratios in the trans do not match the ratios that the EATX is coded for. The other codes are somewhat self explained, see the attached link for the code list. PAY SPECIAL attention to code 36.
You really need the EATX for THAT new trans, or you get your original EATX flashed to match your replacement trans which, given your location, may not be the easiest thing to do. Do you still have the old trans that was in the car?
A604 Transmission Codes
