im working on an 84 2.2 (i think its 84 because theres numbers on the back of the block right above the oil pan that say 12 17 84 i think those are the right ones.... but i know it looked scary like a date)
well 1. whats the best way to get the exhaust manifold studs outa the head? i figure ill just warm the aluminum up with a propane torch so that it expands and they get loose... one i broke the nut off of but theres still room to grab it with vise grips and theres 2 others... 1s fine and the other one has flat spots on the threads from where i die grinded the sides of the nut off
2. whats should i seal the threads with when i put them back in?
and im puting this into a 91 daytona with a standard trans so im getting the hole machined into the crank for the pilot shaft and puting on the 6 bolt flywheel
does anybody happen to have the size and tolerances for the hole? lol
and im gunna try to reuse my clutch off my 8 bolt flywheel it should fit ...right?
and a heads up on anything else that would like to pop up on be would be nice
