Ok I need some help, I can tear a motor down and put it back together blind folded.,but I'm as smart as a box of hair when it comes to tranny's. I know what I want and need but need your guys help to get there. Ok I have a horizon, 10-1+ CR, Comp 131 cam, Long tube header, modded intake and Carb, no cat. The gearing to high, it's the 2.78 and I can't get off the line quick enough, I want the 3.05. Now How do I now which tranny has that , and when I find one how do I get them out. Stupid question I know but again I'm not a tranny guy.
TIA 24kilo
Im not the best trans guy either, but that ratio would come with a heavier car, daytona, lebaron. I would think you just need the ring and pinion from a a413 out of one of those cars. .
james
you don't need to change the ring & pinion (hard) just the transfer gears (easy)
your .91 xfer gears can be replaced with the 1.06s which are super common; if you want more you will have to scavenge a 1.22 set from an EARLY non-2.2 Lbody (rare)
easy to do, just need a gear puller (harmonic balancer puller may work)
I'll buy your 0.91s off ya :)
Sure it'll be a month or so, Just getting my ducks in a row.BTW can I pull them while still in the trans is still in the car? I'm going to put quad cabs on it first, When it gets warmer I'll get on the trans.
yup, can b e done w/ trans in car
remove drivers side wheel; the the xfer gear cover is right there - its the sheet metal cover which your tire rubs on at full lock :)
hard part is taking the big nuts off and pulling the gears
also when putting them back on make sure you use lots of force(like a very good impact) and red loctite, because the will come off and make a mess of the cover
