I'm in need of the final drive and gear set from an a523 trans to complete the install of an OBX in my a568. I would prefer 385 but 377 FD could work too.
Thanks!
So you need dif and cluster shaft you have fiber or brass bulk rings??
I might have it
you may have to elaborate a bit, i dont know all of the tranny lingo! I need the bolt on ring gear and the internal "cluster shaft" as you called it. I dont know another term so, that sounds good to me! Where would I need to look for the brass or fiber ring? Its a '91 tranny if that helps. Thanks
The cluster shaft is the one that has all your gears on it.
if you want to change to a open diff for a a523 the whole diff has to be changed
Cause the a555 and a568 use the same diff and the ring gear is part of the diff bearing
where the a520 and a523 is separate for ring gearthat bolts on
do you have your trans apart yet??
I do have the diff cover off, haven't opened up the rest of it until I know that I can get the parts. yep, i need the cluster shaft and ring gear. I dont need the diff though.
send me some pics of the parts you need i can match up what you need.
Discussion Starter · #7 ·
I'm not sure how to post a pic yet. I do know how to email or send them to your phone though!
