shorter arm more boost??
Yeah, you will need the 86 dist., but I forget exactly why.smkshow said:thanks,so it sounds right?,then all I have to do is replace my valve with a g-valve,and maybe put my old wastegate on this motor,and things should be o.k.?what about the check valve,I never had one,when I open my valve,I never had a vacume leak?is this right?one more thing,maybe you can help me with,when I had my 86 engine,I had the chip in it,my distributor on that engine screwed up,I know the 86 chip wont work with an 85 distributor,I seem to have missplaced it,should I get a chip again?or is it o.k.for medium boost?are they even still available?tough around here...thanks alot for the help...
