Hey guys, quick question. I installed my accufab afpr on the fender well with new injector rail and braided lines. My issue isbthat when i key on, the fuel pressure runs all of the way up to 90+psi. I have a walbro in tank. The one time it blew the rubber line off of the tank. Next time it actually ruptured the line. I have unscrewed the adjuster all of the way out so its loose. And i have the -6an from the rail hitting the center fitting and the -4an going to the tank return line. Is there a possibility that the 1/4 line wont flow enough when the motor is not running to keep fuel pressure at a manageable level? I have tested flow out of the return at the tank so i know its not clogged.
Thanks guy
Thanks guy
